My outer tub is leaking,I suspect that I need to change the gaskets. I already have the top off and the agitater out,but I can't seem to get the inner tub out. do I need to use a gear puller or does the assembly have bolts underneath? I don,t want to take apart any moore of this machine than I have to.
You need a spanner wrench to go farther. There's a few posts on here with the part number.
Nat
Originally Posted by: libertyappl You need a spanner wrench to go farther. There's a few posts on here with the part number.
Nat A spanner wrench won,t work on this perticular machine, but thanks anyway.
