tomrehn
#1 Posted : Tuesday, January 13, 2009 2:43:12 PM(UTC)
tomrehn
My outer tub is leaking,I suspect that I need to change the gaskets. I already have the top off and the agitater out,but I can't seem to get the inner tub out. do I need to use a gear puller or does the assembly have bolts underneath? I don,t want to take apart any moore of this machine than I have to.
libertyappl
#2 Posted : Wednesday, January 14, 2009 6:04:35 AM(UTC)
libertyappl
You need a spanner wrench to go farther. There's a few posts on here with the part number.
Nat
tomrehn
#3 Posted : Wednesday, January 14, 2009 3:23:27 PM(UTC)
tomrehn
Nat
A spanner wrench won,t work on this perticular machine, but thanks anyway.
Re-assembly after inner tub removal (Washer Repair)
by Marlee29 1/5/2013 11:30:02 AM(UTC)
inner tub removal, tub wont com out, (Washer Repair)
by sbeard318 11/30/2012 5:09:12 PM(UTC)
Inner tub removal (Washer Repair)
by danceilike 8/13/2008 12:14:07 PM(UTC)
