samev
#1 Posted : Wednesday, April 13, 2011 1:49:04 PM(UTC)
samev
When Setting Oven Temp At Say 350 When Oven Beeps And Says 350 The Oven Is Not At That Temp For A While. I Changed The Sensor Didn't Make Any Difference What Is The Next Step Changing The Control Panel? Thanks Sam
#2 Posted : Thursday, April 14, 2011 4:01:06 AM(UTC)
When it says it is at 350 what is the actual temperature.
Most units will let you calibrate plus/minus 35 degrees.
If way off then you probably need a new control board (Item 2 in Section 2)
Replacement parts for WHIRLPOOL KESC307HBS8 ELECTRIC RANGE | AppliancePartsPros.com
The following may help with your repair
Whirlpool KAC-34 KitchenAid Self-Cleaning Slide-In Electric Range Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
samev
#3 Posted : Thursday, April 14, 2011 4:37:30 AM(UTC)
samev
is this part retunable if this is not the problem? sam
samev
#4 Posted : Thursday, April 14, 2011 4:40:13 AM(UTC)
samev
is this part returnable if this is not the problem? sam
#5 Posted : Thursday, April 14, 2011 9:58:08 AM(UTC)
If you do some diagnostics then it is returnable.
Please read the AppliancePartsPros return policy.
Note: I do not work for AppliancePartsPros. I just spend some time on their forum trying to help a few people.
