When Setting Oven Temp At Say 350 When Oven Beeps And Says 350 The Oven Is Not At That Temp For A While. I Changed The Sensor Didn't Make Any Difference What Is The Next Step Changing The Control Panel? Thanks Sam
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  is this part retunable if this is not the problem? sam
is this part returnable if this is not the problem? sam
If you do some diagnostics then it is returnable. Please read the AppliancePartsPros return policy.
Note: I do not work for AppliancePartsPros. I just spend some time on their forum trying to help a few people. |
