Dishwasher not cleaning dishes or soap out of tray. I installed a new inlet valve that did'nt fix the problem. any help out there:rolleyes: :rolleyes: ????
Here are your parts Replacement parts for MAYTAG DWU6750AAB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.comHere is a manual although it does not show your unit I believe the pump is the same. 16007823 Maytag Dishwasher Service Manual - ApplianceDigest.comYou have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer. Could be just the pump needs cleaning out re: filters and chopper /impeller. Most units fill to just below the heating element. If you are not sure that iot is getting enough water even with the new valve you could add a quart or so of water after each fill. If it then runs OK you know that you have a fill problem. Just be careful that you do not overfill the unit. |
THIS FORUM IS DEAD!!!!!!! |
