hi my dishwasher give error opened the door i see the water level under the heat element what should i check? thanks
Originally Posted by: leosar  hi my dishwasher give error opened the door i see the water level under the heat element what should i check? thanks i have to mention too that there is too much steam in the cabinet and water too hot
