leesa in pcola
#1 Posted : Thursday, April 7, 2011 10:06:41 AM(UTC)
leesa in pcola
Hi The Dishwasher Will Fill With Water But Will Not Run Through The Cycle. It Humms And The Dail Will Move Througth
Like Its Running. It Sounds Like It Wants To Kick On ,but Doesn't. Anything You Can Tell Me To Fix The Problem?
leesa in pcola
#2 Posted : Thursday, April 7, 2011 10:18:58 AM(UTC)
leesa in pcola
Originally Posted by: leesa in pcola Go to Quoted Post
Hi, The dishwasher will fill with water but will not run through the cycle. It humms and the dail will move througth
like its running. With every cycle change it makes a sound like it wants to kick on ,but doesn't. Also, the water doesn't drain out, I've done the baking soda and vinegar trick to no avail. Anything You Can Tell Me To Fix The Problem?
:confused:
#3 Posted : Thursday, April 7, 2011 2:20:00 PM(UTC)
Leesa,
Most likely the problem is a bad (stock) pump. You can try to fix the old pump by installing the new impeller and seal kit or by replacing the whole pump & motor assembly. You can find much more useful information in one of our previous threads: http://forum.appliancepartspros...ter-flow.html#post368518
- The pump impeller and seal kit Part number: AP631386
- The pump & motor assembly Part number: AP2616850
leesa in pcola
#4 Posted : Thursday, April 7, 2011 3:12:33 PM(UTC)
leesa in pcola
Thanks for the info Gene. I'll give it a try and let you know how it turns out.
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
