Kupuna
#1 Posted : Tuesday, April 5, 2011 1:35:32 PM(UTC)
Kupuna
A falling object cracked off the shaft of the water temperature switch on this nearly-new washer/dryer stack. I know better than to pull on the main timer knob (and the dryer?). How can I safely get the timer knob off so I can remove the front panel and replace the water temp. switch?
Also, is there an "exploded view" of this unit on your site?
Thanks!
sidfink43
#2 Posted : Thursday, April 7, 2011 4:43:34 PM(UTC)
sidfink43
Well not having on in front of me, I think on this model the timer knob for the washer has a cover cap on it. Pry the cover cap off and you can get the the prongs that hold the knob on.
