eramcpt
#1 Posted : Thursday, January 8, 2009 7:52:19 AM(UTC)
eramcpt
i have a whirlpool cabrio model number WTW6600SB2 that gives me an error F1 and i need help
libertyappl
#2 Posted : Thursday, January 8, 2009 8:36:11 AM(UTC)
libertyappl
This is what the tech sheet says on the F1 code
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an
out of range pressure signal.
➔ Check pressure hose connection from tub
to machine/motor control. Is hose pinched
or kinked?
➔ If F then 1 repeats numerous times after
POWER is pressed and the pressure hose
connection is not pinched or kinked,
replace the machine/motor control
Hope this helps, here's the breakdown Model WTW6600SB2
Nat
eramcpt
#3 Posted : Thursday, January 8, 2009 9:24:11 AM(UTC)
eramcpt
thanks for your help
god bless
eramcpt
whirlpool washer problem (Washer Repair)
by glo7799 10/9/2012 8:09:40 AM(UTC)
Whirlpool Washer Problems (Washer Repair)
by GK12 3/4/2012 1:28:37 PM(UTC)
Whirlpool washer problem (Washer Repair)
by sliderrst 1/6/2010 10:53:54 PM(UTC)
by ronhn 1/1/2010 11:22:44 AM(UTC)
Whirlpool Washer problems (Washer Repair)
by cb1474 7/13/2009 8:44:04 AM(UTC)
