bode21
#1 Posted : Wednesday, January 7, 2009 4:58:29 PM(UTC)
bode21
I have a GE Profile Quiet Power II. The soap dispenser will not close so the unit's door will not close and lock. What is the possible solution? Do I need to remove the entire front panel on the unit?
Thanks for your help.
#2 Posted : Thursday, January 8, 2009 2:27:51 AM(UTC)
You will need to remove the door's inner panel to see what has happened.
Here is a link that may help
http://www.applianceaid.com/dish.html
Check ot 24 and 23 (at the bottom)
bode21
#3 Posted : Thursday, January 8, 2009 6:08:38 AM(UTC)
bode21
Denman--
Thanks forthe reply; the soap dispenser does not lock in place when rotated. I have removed the cover but see no obvious problem. It's spring loaded so could that be the problem?
#4 Posted : Thursday, January 8, 2009 11:05:28 AM(UTC)
Make sure the arm from the timer is letting it latch
Jenn Air Dishwasher soap dispenser door wont open (Dishwasher Repair)
by Guest 10/22/2021 5:22:26 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
GE Cafe Soap Dispenser (Dishwasher Repair)
by Gary Ceepo 6/19/2017 10:04:55 AM(UTC)
Kitchenaid Dishwasher soap dispenser won't open during cycle (Dishwasher Repair)
by dawnbeaufort@gmail.com 12/18/2015 3:22:47 PM(UTC)
inoperable soap dispenser (Dishwasher Repair)
by Luth 10/26/2015 12:17:47 PM(UTC)
kitchenaid dishwasher soap dispenser not opening (Dishwasher Repair)
by tsquilanti 9/16/2015 10:44:29 AM(UTC)
Remove & Install Soap Dispenser (Dishwasher Repair)
by doloresann 1/17/2015 7:55:32 AM(UTC)
water leaking from soap dispenser housing (Washer Repair)
by suekevin 1/8/2015 12:21:56 PM(UTC)
Bosch Soap Dispenser Rattles (Dishwasher Repair)
by Jmccullough 5/28/2014 4:21:11 PM(UTC)
Can someone help me with a Bosch soap dispenser (Dishwasher Repair)
by jonjonbear 3/19/2014 6:50:24 AM(UTC)
Kenmore soap dispenser not opening (Dishwasher Repair)
by Woodworker2001 2/9/2014 7:09:38 AM(UTC)
soap dispenser not opening and short cycle (Dishwasher Repair)
by wkroeplin 12/5/2013 2:48:34 PM(UTC)
maytag soap dispenser won't open (Dishwasher Repair)
by jjleip11 9/15/2013 1:44:50 PM(UTC)
Bosch Dishwasher Soap Dispenser won't ope (Dishwasher Repair)
by jaredw 5/31/2013 3:04:58 PM(UTC)
Maytag Soap Dispenser Not Opening to Dispense Soap (Dishwasher Repair)
by tomball 1/22/2013 6:48:46 PM(UTC)
