tsquilanti
#1 Posted : Wednesday, September 16, 2015 10:44:29 AM(UTC)
tsquilanti
Hi I have a KitchenAid KUDS01FLSS6 and the soap dispenser door is not opening. I removed the kickplate but no tech sheet to be found (prior homeowner must have lost it). The door does open when i run the diagnostic cycle, so what do i do next? does this leave me with either a) faulty wiring from control board to dispenser, or b) a defective control board?
I have a multi-meter but am unsure of how to check continuity of the wires between the dispenser and the control board. Any help would be appreciated!
thanks, Todd
#2 Posted : Thursday, September 17, 2015 6:23:09 AM(UTC)
Parts for KitchenAid KUDS01FLSS6 Dishwasher - AppliancePartsPros.com
First I would check the dispenser resistance at the control board P2-4 to P10, should be 280 to 340 ohms.
Note that even if it is OK it does not mean that the dispenser is OK as it may have other problems.
