dgiardina
#1 Posted : Wednesday, January 7, 2009 5:42:18 AM(UTC)
dgiardina
Our fridge/freezer quit cooling. the evap fan works. compressor gets hot to the touch. I can't find the compressor relay to attempt to check it. My model has the capacitor that plugs in to the Starter-PTC.
Thanks !!
libertyappl
#2 Posted : Wednesday, January 7, 2009 6:05:09 AM(UTC)
libertyappl
Is there any clicking noise near the compressor? A lot of frost or ice build up on the inside rear wall of the freezer?
The start PTC is usually connected to the relay.
Nat
dgiardina
#3 Posted : Wednesday, January 7, 2009 6:15:04 AM(UTC)
dgiardina
haven't heard any clicking noises. inside the freezer compartment is 49 degrees & the back wall doesn't have any frost, but I haven't taken apart the freezer to see if their is any ice behind it.
so the start ptc is integrated with the relay? I only have the capacitor, ptc, then compressor.
Here's the pic of the ptc - Model FRT21LRGW5
If it's in the ptc, how do i test it?
