My GE Potscrubber Dishwasher will not cycle through the wash cycles. -The knob is not stuck and the washer will cycle through if you turn manually. -I checked the timer connections all attached and no corrosion. -I do not have meter so can not check -I checked the water and it appears hot -The washer will cycle through the Heated Dry cycle and dries appropriately?
Can it be anything other than the timer? I have located timer on the internet for about $75. Washer is old but I do not want to replace if I can fix for under $100.
Any advice would be greatly appreciated.
Roho, Most likely the problem is a bad timer and you can buy it from Appliance Parts Pros for $68.45 - The part number for the timer is AP2039702Here are the break down diagrams for GE dishwasher Model GSD3610Z05AAGene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Roho, Most likely the problem is a bad timer and you can buy it from Appliance Parts Pros for $68.45 - The part number for the timer is AP2039702Here are the break down diagrams for GE dishwasher Model GSD3610Z05AAGene. Thanks for the response and links Gene. I will let you know.
Works great. Thanks again
You are welcome. I'm glad you were able to fix it.
