regina holland
#1 Posted : Tuesday, January 6, 2009 3:51:33 PM(UTC)
regina holland
My oven does not work on my Maytag range. The broiler works, but when I set the oven to 350 degrees, it gets to 100 degrees and stays at 100. Please help me.
sugarhillctd
#2 Posted : Wednesday, January 14, 2009 2:34:25 PM(UTC)
sugarhillctd
Regina,
I'm a newby here too. But I have been reading lots of posts about your and my problem (our Maytag is a few years older but pretty similar).
First pull the shelves out of your oven. Then lift out the "floor" of the oven- it might lift up in the rear and then the front.
Then read this (substitute broiler for oven):
http://forum.appliancepartspros...iler-will-not-light.html
Hope this helps steer you in the right direction.
I found quite a bit of info just looking through LOTS of pages on the
"Oven Repair (including Ranges and Cooktops) " forum.
Good luck.
John
Oven does not work but no fault codes? (Oven Repair (including Ranges and Cooktops))
by Ruby roars 6/5/2015 10:52:55 AM(UTC)
Kenmore Elite Electric Range - lower oven does not work after "self cleaning" cycle (Oven Repair (including Ranges and Cooktops))
by AKJim 11/23/2014 5:19:54 PM(UTC)
Oven does not work; everything else is fine (Oven Repair (including Ranges and Cooktops))
by 9hackler 9/21/2014 5:07:11 PM(UTC)
Upper oven does not work (Oven Repair (including Ranges and Cooktops))
by billhoch77@yahoo.com 6/24/2014 11:25:36 AM(UTC)
Whirlpool oven does not work but burners on top do. (Oven Repair (including Ranges and Cooktops))
by formula2fast 12/25/2012 7:13:16 AM(UTC)
electric oven does not work (Oven Repair (including Ranges and Cooktops))
by pawpawrick 10/8/2012 9:35:37 AM(UTC)
Oven does not work (Oven Repair (including Ranges and Cooktops))
by smodes 8/2/2012 11:08:02 AM(UTC)
whirlpool oven does not work (Oven Repair (including Ranges and Cooktops))
by Alketa 6/9/2011 8:23:05 AM(UTC)
kenmore oven does not work cooktop works (Oven Repair (including Ranges and Cooktops))
by voles 3/9/2011 5:38:56 PM(UTC)
Oven does not work after cleaning (Oven Repair (including Ranges and Cooktops))
by mzarahemla 1/26/2011 5:32:35 PM(UTC)
Oven does not work/heat (Oven Repair (including Ranges and Cooktops))
by karenlu 1/4/2011 8:58:56 AM(UTC)
by esauseda 10/18/2010 11:05:41 AM(UTC)
Oven does not work! Frigidaire/Electrolux (Oven Repair (including Ranges and Cooktops))
by justbarbie 10/3/2010 6:45:29 PM(UTC)
Oven Does Not work UUUGH (Oven Repair (including Ranges and Cooktops))
by Puwata 8/8/2010 10:01:45 AM(UTC)
Viking dual fuel range oven does not work (Oven Repair (including Ranges and Cooktops))
by Ren10 4/22/2010 9:31:38 AM(UTC)
