Discuss
Broiler will not light
 in
Hi My oven is a Amana args7650ww s/n 0008131794 manufacture # p1130765nww The broiler does not start. What can I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broiler will not light
  #1 (permalink)
Old 01-06-2009, 07:30 AM
Junior Member
mmason3122 is on a distinguished road
Default Broiler will not light
Model Number: args7650ww   Brand: Amana   Age: 5 - 10 years
Hi
s/n 0008131794
The broiler does not start. What can I do to fix it.
Ads By Google
Related Models
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NL RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NW RANGE- S/C S/I DDRAFT GAS
Amana ARR3100W RANGE- S/C S/I DDRAFT GAS
Amana ARR3400L RANGE- S/C S/I DDRAFT GAS
Amana ARR3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR3601LL Range - S/c S/i Ddraft Gas
Amana ARR3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARR3601WW Range - S/c S/i Ddraft Gas
Amana ARR3601WW RANGE- S/C S/I DDRAFT GAS
Amana ARR5200L RANGE- STD MWAVE ELE
Amana ARR5200W RANGE- STD MWAVE ELE
Amana ARR600 RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 01-06-2009, 09:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the igniter glow?
If it does but the gas does not flow then the igniter is bad and has to be replaced.
If it does not then you have to disconnect the igniter wires and check for 120VAC to the igniter while the control calls for Broil.
If there is 120VAC then the igniter has to be replaced.
If there is no proper voltage then the control board has to be replaced.
- The part number for the Broil igniter is AP2934763. You have to use the bracket from the old igniter.
- The part number for the control board is AP4041311
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-07-2009, 07:04 AM
Junior Member
Default
Thanks for the help.
How do check for the power?
Do I need to remove the back panel from the stove?
Matt
  #4 (permalink)
Old 01-07-2009, 01:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Matt,
You have to have a simple multimeter.
You have to pull the igniter out as far as the wires will let you. There should be a wire nuts for each wire. Disconnect these wire nuts and measure the voltage between the two wires coming to the igniter while the control calls for Broil.
If you can pull the range out of the wall and remove the rear panel, then you can access the igniter wires easier way.
__________________
  #5 (permalink)
Old 11-23-2010, 08:53 AM
Junior Member
spystyle is on a distinguished road
Default
Good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven won't light, broiler does! tryingtobeahandyman Oven Repair (including Ranges and Cooktops) 2 11-23-2010 06:38 PM
Gas broiler won't light afisc2910 Oven Repair (including Ranges and Cooktops) 0 09-05-2009 07:01 AM
Broiler won't light dvici Oven Repair (including Ranges and Cooktops) 3 05-01-2009 07:04 AM
broiler won't light pilot light burns copolit Oven Repair (including Ranges and Cooktops) 3 11-19-2008 10:10 PM
Broiler does no light hutman69 Oven Repair (including Ranges and Cooktops) 3 11-18-2008 03:05 PM
