Door handle on refrig side is loose. How can I tighten it or replace it if required?
Here is your parts breakdown Model GS5SHAXNB00Looks like you pull upward on the handle and it should release from the retaining clips |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the info but I tried to push upward but NO GO. Again thanks!
If you look at Item 5 the clip in the "Refrigerator door parts " section You can see there is a small clip that holds the handle's bolt i the clip. You may have to use more force while having another person hold the door down.. Perhaps someone else will know a trick to release the handle. |
Two people did the trick. I hope it goes back just as easy. Thankyou!! Fixed!!! Thankyou again!
