lvitiello
#1 Posted : Tuesday, January 6, 2009 3:25:21 PM(UTC)
lvitiello
Door handle on refrig side is loose. How can I tighten it or replace it if required?
#2 Posted : Wednesday, January 7, 2009 7:04:53 AM(UTC)
Here is your parts breakdown
Model GS5SHAXNB00
Looks like you pull upward on the handle and it should release from the retaining clips
lvitiello
#3 Posted : Wednesday, January 7, 2009 10:42:16 AM(UTC)
lvitiello
Thanks for the info but I tried to push upward but NO GO. Again thanks!
#4 Posted : Wednesday, January 7, 2009 12:14:54 PM(UTC)
If you look at Item 5 the clip in the "Refrigerator door parts " section
You can see there is a small clip that holds the handle's bolt i the clip.
You may have to use more force while having another person hold the door down..
Perhaps someone else will know a trick to release the handle.
lvitiello
#5 Posted : Wednesday, January 7, 2009 4:49:20 PM(UTC)
lvitiello
Two people did the trick. I hope it goes back just as easy. Thankyou!! Fixed!!! Thankyou again!
