Martha Shelby
#1 Posted : 17 years ago
Martha Shelby
The washer will wash but will not go into the rinse or spin cycle. You can hear a small humming noise....any suggestions of what might be wrong?
#2 Posted : 17 years ago
If the washer agitates, probably a bad timer, just remove cover and check contacts, if burnt this confirms a bad timer. You can order one by clicking on your model #
Roper washer will not spin or drain (Washer Repair)
by Jfriedm 15 years ago
Washer will not spin or drain (Washer Repair)
by templejazz82 16 years ago
washer will not spin or drain - leaks (Washer Repair)
by BARCHER 16 years ago
by Martha Shelby 17 years ago
