Martha Shelby
#1 Posted : Tuesday, October 23, 2007 8:01:38 AM(UTC)
Martha Shelby
The washer will wash but will not go into the rinse or spin cycle. You can hear a small humming noise....any suggestions of what might be wrong?
#2 Posted : Wednesday, October 24, 2007 2:59:35 AM(UTC)
If the washer agitates, probably a bad timer, just remove cover and check contacts, if burnt this confirms a bad timer. You can order one by clicking on your model #
Roper washer will not spin or drain (Washer Repair)
by Jfriedm 6/15/2010 5:37:38 AM(UTC)
Washer will not spin or drain (Washer Repair)
by templejazz82 6/24/2009 4:55:28 AM(UTC)
washer will not spin or drain - leaks (Washer Repair)
by BARCHER 4/29/2009 6:23:57 AM(UTC)
by Martha Shelby 10/23/2007 8:00:21 AM(UTC)
