3 Pages123>
Dave14
#1 Posted : Monday, October 22, 2007 1:58:23 PM(UTC)
Dave14
When my icemaker empties, it overfills by alot which flows into the ice bin and even into the frezzer below. It also seem like the ice has a hard time ejecting (I assume because its overfilled). Will replacing the water valve fix it?
The original part# was 2181730, but all the parts sites I went on showed it as 2188542. What about this?
#2 Posted : Monday, October 22, 2007 3:07:49 PM(UTC)
Hi Dave
Does the ice maker overflow or it's leaking through?
If it's leaking then the ice maker has to be replaced.
If it's overflowing then you can try to adjust the amount of water coming into the ice maker first, before replacing any parts. Remove the front cover from the ice maker and you'll find the adjustment screw on the right side. Turn it half way clock wise and check how it will fill up. Possible you'll have to turn it more. Let me know if adjustment helped.
- The part number for the new ice maker AP2984633
The part number for the water inlet valve has been changed by the Whirlpool.
Good luck.
Dave14
#3 Posted : Monday, October 22, 2007 4:28:10 PM(UTC)
Dave14
Thanks Gene...it definitely overfills the ice tray and then runs down into the ice bin and below. I'll give the adjustment a shot before replacing the valve.
Thanks again.
#4 Posted : Monday, October 22, 2007 4:46:36 PM(UTC)
Dave
I do not think the problem is a bad water valve. If water flow to the ice maker stops then most likely the problem is the ice maker itself.
Dave14
#5 Posted : Tuesday, October 23, 2007 3:14:26 AM(UTC)
Dave14
Listening to the water flow when its refilling, I can tell that the water is flowing into the ice tray much longer than it used to before I had the problem. I just figured that the valve was staying open too long and was defective. What do you think?
#6 Posted : Tuesday, October 23, 2007 7:43:38 AM(UTC)
Did you do the adjustment?
Dave14
#7 Posted : Tuesday, October 23, 2007 12:30:40 PM(UTC)
Dave14
I turned the adjustment screw and it still overfilled as it did before. Do you think the whole unit needs replaced? How tough is it to do?
#8 Posted : Tuesday, October 23, 2007 7:04:33 PM(UTC)
Do you have the water dispenser on your fridge as well?
If you do then switch around plugs on the water valve, push the lever for the drinking water and monitor the water feeding tube for the ice maker. If water flow to the ice maker stops right after you released the drinking water lever then replace the ice maker. If not - replace the water valve.
Keep me updated, please.
#9 Posted : Wednesday, October 24, 2007 1:41:34 AM(UTC)
Most icemakers have a water fill for around 9 seconds. If you empty icemaker mold, fill for 9 seconds and it overflows, you have a bad water solenoid. or low water pressure to it.
Dave14
#10 Posted : Friday, October 26, 2007 5:50:43 AM(UTC)
Dave14
I do have the water dispenser, but the two lines are different diameter and can't be switched. Any suggestions?
3 Pages123>
