gmapopo09@gmail.com
#1 Posted : Monday, March 28, 2011 8:20:20 AM(UTC)
gmapopo09@gmail.com
My dryer will not heat. Have replaced the heating element and the thermostat. :(
#2 Posted : Wednesday, March 30, 2011 3:34:56 AM(UTC)
Replacement parts for WHIRLPOOL WED6400SW1 29" ELECTRIC DRYER | AppliancePartsPros.com
Here is a service manual.
Whirlpool 8178584 Cabrio Dryer Service Manual - ApplianceDigest.com
The first thing to check is the power.
The motor will run on half the line but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Whirlpool Cabrio Dryer Model wgd6200sw2 is making a lot of noise (Dryer Repair)
by creamerdp 4/25/2017 12:23:56 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Whirlpool Cabrio Dryer blew thin Thermal fuse for 2nd time (Dryer Repair)
by ziggy75 11/22/2016 5:47:37 PM(UTC)
Whirlpool Cabrio dryer control board replacement (Dryer Repair)
by JTR1970 11/15/2013 3:25:51 PM(UTC)
Cabrio Dryer (Dryer Repair)
by turdbird 7/28/2013 6:58:24 AM(UTC)
Cabrio Dryer runs HOT after intial use (Dryer Repair)
by ROCJR 7/13/2013 5:52:49 AM(UTC)
Whirpool Cabrio Dryer F25 (Dryer Repair)
by Hallettpeak 7/29/2012 10:04:07 PM(UTC)
Whirlpool Cabrio Dryer Model WED7800XW (Dryer Repair)
by pint4 7/25/2012 2:34:28 AM(UTC)
whirlpool cabrio dryer heating element repair (Dryer Repair)
by bradman67 3/17/2012 11:02:03 AM(UTC)
Cabrio dryer popping thermal fuses (Dryer Repair)
by Lil Man 12/20/2011 3:28:17 PM(UTC)
(AF) air flow error code on cabrio dryer (Dryer Repair)
by dmay21 9/28/2011 7:55:09 PM(UTC)
need to know how to get a control panel out of cabrio dryer (Dryer Repair)
by millbe 8/15/2011 2:23:12 PM(UTC)
My Whirlpool Cabrio Dryer.... (Dryer Repair)
by ScottyNick 4/30/2011 10:50:59 AM(UTC)
Grinding noise on Cabrio Dryer (Dryer Repair)
by Gut_feeling 4/25/2011 2:20:00 PM(UTC)
Whirlpool Cabrio Dryer (Dryer Repair)
by scottheron 11/9/2009 5:50:14 AM(UTC)
