The condensor cooling fan is not coming on when the compressor kicks on. Could this just be a defective fan motor?
Originally Posted by: David Brooks  The condensor cooling fan is not coming on when the compressor kicks on. Could this just be a defective fan motor? David, Yes, you most likely have a defective condenser fan motor. Part number: AP3120994
Both the compressor and the fan motor use the same power source, from the control, so if one works, the other should as well(unless you have a loose connection or broken wire). Good Luck, :) :) :)
