David Brooks
#1 Posted : Sunday, March 27, 2011 7:46:36 AM(UTC)
David Brooks
The condensor cooling fan is not coming on when the compressor kicks on. Could this just be a defective fan motor?
Joe / APP Team
#2 Posted : Monday, March 28, 2011 8:51:55 AM(UTC)
Joe / APP Team
David,
Yes, you most likely have a defective condenser fan motor.
Part number: AP3120994
Both the compressor and the fan motor use the same power source, from the control, so if one works, the other should as well(unless you have a loose connection or broken wire).
Good Luck,
