Tex Red
#1 Posted : Saturday, March 26, 2011 12:12:32 PM(UTC)
Tex Red
I am having a hard time figuring out why this dryer isn't heating. Here is what I have done and found so far:
L1 = 110
L2 = 110
Across both = 220
Red wire (L1) at timer = 110
Yellow wire at timer = 110 when dryer is started
Brown wires (2) at timer = 110
With the dryer running I get 110 at both thermostats, and at the three element connections. When I try to test the element connections across each other I don't get anything. I also don't get a reading at the door switch or the safety switch.
When I do a continuity test I get zero (or near zero) on both thermostats, the door switch and the safety switch. The elements give me a reading around 20. And the timer drive motor gives me a reading of 1996
I hope that makes sense. Any thoughts on what's wrong? I appreciate any help y'all could offer.
Tex Red
#2 Posted : Sunday, March 27, 2011 11:17:47 AM(UTC)
Tex Red
Bump ... Any thoughts any one?
Tex Red
#3 Posted : Monday, March 28, 2011 1:47:39 PM(UTC)
Tex Red
Bump ... Again ... Anyone have any thoughts about what the problem could be?
sidfink43
#4 Posted : Wednesday, March 30, 2011 3:35:09 PM(UTC)
sidfink43
You should not be testing the thermostats or anything else with the dryer running. Disconnect it for all testing.
Wherever you have no continuity across a thermostat, there is your problem.
rca dryer not heating (Dryer Repair)
by kendro 4/2/2009 4:19:50 PM(UTC)
