No gas in oven. Igniter or glow bar "glows" brightly in fact we tested it for resistance it read about 190 ohms. Could it be the Safety valve? That too is gettting resistance but not sure what is required to get oven started. The stove range works fine. Its just the oven no gas being alowed out. Does GE part# WB19K31 ot AP2022762 parts pros# for safety valve sound right? Any help is appreciated. Thanks
Replace the ignitor, it is not glowing bright enough to open the gas valve.
