All burners work, broiler glows and starts up but when set oven temp the electrical ignition wont come on? Any Help
yes it is most likely the ignitor. a good way to be sure is to check the gas valve for continuity. but in thirty years, i have only replaced and hand full of gas valves, and a ton of ignitors. tom [url=]applianceeducator.com - parts[/url]
