dmoc
#1 Posted : Saturday, January 3, 2009 6:41:20 AM(UTC)
dmoc
When I try starting the dryer, the sensing light comes on and there is a single beep. But it will not start. As if there is a cut off.
Is there anything I can do to find out more? Is there a diagnostic test that might give an indication?
I read where a repair technician removed the front of the dryer, vacuum'd and it then it started.
I had a large down coat with a gym shoe (to bounce and fluff the garment). That was the last thing I dried.
I hope someone can help. My email is plf999@aol.com.
#2 Posted : Saturday, January 3, 2009 8:56:40 PM(UTC)
Remove the toe panel and check if the belt is not broken. There is a special "belt broken" switch which prevents the dryer from start if the belt brakes.
Here are the break down diagrams for the Whirlpool dryer Model GGW9250PW0
Franknoto
#3 Posted : Monday, July 8, 2013 5:43:31 AM(UTC)
Franknoto
Groups ready for retrieval: Registered
I have the same problem. Both the belt and fuse are Ok. What did you find was the problem?
mawskin
#4 Posted : Wednesday, July 17, 2013 7:09:57 PM(UTC)
mawskin
Found nothing yet. I relly need the help. It's not the belt because the drum turns when I press the More time & Less time buttons. It shuts off after a short time
HumboldtRepairMan
#5 Posted : Thursday, July 18, 2013 6:15:34 PM(UTC)
HumboldtRepairMan
Ok in your initial post you said it has a single beep and doesn't start or turn at all?......now your saying timed dry turns for awhile then shuts off?
mawskin
#6 Posted : Thursday, July 18, 2013 9:02:10 PM(UTC)
mawskin
I had to order the Control & Display Board from Sears Parts. It will take 5 - 7 work days.
