jtmcvickar
#1 Posted : Wednesday, March 23, 2011 11:55:10 AM(UTC)
jtmcvickar
Spring on left door hinge broke. Tried to get to hinge with no success. Cannot remove side panel. Looks like top must be removed along with other trim. Need instructions to get to and replace hinge.
#2 Posted : Wednesday, March 23, 2011 2:38:20 PM(UTC)
Remove sealed burners:
a) Remove grates
b) Turn each burner CCW about 2 inches to loosen.
c) Once loose, lift the burner straight up and out of the mounting hole.
d) Label and disconnect wire terminals from burner. Remove screw and washer (securing burner support to main top) from the burner openings.
Remove the main top:
a) Raise the front edge of the maintop and pull forward.
b) Lift maintop assembly from the oven chassis.
Now you can remove the side panel.
- The door hinge kit Part number: AP4012074
