How in the world does one replace a burnout light bulb in this microwave? completely stumped. where is is located and how do I reach it? HELP!!
Originally Posted by: E610046 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How in the world does one replace a burnout light bulb in this microwave? completely stumped. where is is located and how do I reach it? HELP!! :) :) Here are your part number and light replacement procedure. You will need to be extremely careful when performing the repair. You'll be working near the high voltage components, and could get hurt badly. Part number: AP3038375
Outer Case Removal
1. Remove screws securing outer case to chassis. 2. Push outer case approximately 1 inch to the back of the unit, which will free case from front plate. 3. Lift outer case from chassis. 4. Reverse procedures to reinstall. Lamp Socket Removal
1. Remove outer case, see “Outer Case Removal” procedure. 2. Remove wire leads from lamp socket terminals. 3. Remove screw securing lamp socket to air duct assembly. 4. Replace and reassemble in reverse order.
Good Luck, :) :) :)
