2 Pages<12
classicheepfan
#11 Posted : Saturday, January 3, 2009 2:42:36 PM(UTC)
classicheepfan
Originally Posted by: kayakcrzy Go to Quoted Post
Put 1 of your meter leads on one terminal on the thermal fuse, and the other meter lead on the other terminal o the thermal fuse. Make sure you pull the wires off. Also pull the wires off the part you are checking. Tom
I'm guessing that is the white, plastic piece?
classicheepfan
#12 Posted : Sunday, January 4, 2009 8:51:26 AM(UTC)
classicheepfan
Originally Posted by: denman Go to Quoted Post
You want to measure between the contacts
This may help
http://forum.appliancepartspros...continuity-ohmmeter.html
I read through this and checked everything on the back of the dryer. I got a reading of 0 on all of the checks except for the purple wires which gave me a reading of 7. It seems that all of these components are giving me the proper reading. Is there something else I should be checking?
Guest (4)
2 Pages<12
