Originally Posted by: kayakcrzy Put 1 of your meter leads on one terminal on the thermal fuse, and the other meter lead on the other terminal o the thermal fuse. Make sure you pull the wires off. Also pull the wires off the part you are checking. Tom I'm guessing that is the white, plastic piece?
Originally Posted by: denman I read through this and checked everything on the back of the dryer. I got a reading of 0 on all of the checks except for the purple wires which gave me a reading of 7. It seems that all of these components are giving me the proper reading. Is there something else I should be checking?
