miccrs
#1 Posted : Friday, January 2, 2009 1:52:55 PM(UTC)
miccrs
I have had water pooling in front of the left corner of this unit since it was new-the pooling occurs on the floor. I cannot see if there is a drain pan underneath since it is completely sealed...I assume there is not. How would I get to that area of this unit???
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Frigidaire - Water Leaking from Electronic Defrost Control Area????? (Trash Compactor Repair)
by BJPrice 2/1/2018 3:20:07 PM(UTC)
Water leaking from brand new LG door in door fridge (Refrigerator & Freezer Repair)
by Jason B 7/20/2017 12:58:06 PM(UTC)
Water Leaking at Water Inlet Valve (Refrigerator & Freezer Repair)
by marshmore 12/24/2015 8:00:34 AM(UTC)
water leaking? in freezer (Refrigerator & Freezer Repair)
by chknmom 10/16/2015 3:50:20 PM(UTC)
water leaking on floor (Refrigerator & Freezer Repair)
by capetish 8/23/2015 6:39:00 PM(UTC)
Ice build up bottom of the freezer and water leaking the front door unto the floor (Refrigerator & Freezer Repair)
by BEbner 5/22/2015 1:56:55 PM(UTC)
water leaking from soap dispenser housing (Washer Repair)
by suekevin 1/8/2015 12:21:56 PM(UTC)
