my mixer makes a clanking noise when I turn it on.Could it be a sacrafitial gear .I took the brushes out just to check for wear and put them back in and it does'nt run at all(I did replace them properly).I'm trying to disassemble the mixer to check for any obvious signs of wear.How can I remove the pin that is pressed in to the bottom of the main mixer body.Thanks for your help.
