I filled the icemaker manually and it worked. How do I test to see if the fill lines are frozen? Thanks!
Remove the ice maker and visually inspect the water feeding tube. If you could not see, try to put in a stick. Post the results.
Gene. The model number you posted is incomplete. There suppose to be a few more letters and digits.
Thanks, I'll let you know how it goes Complete model # is ET18PKXFW01
