carinc
#1 Posted : Friday, January 2, 2009 6:20:44 AM(UTC)
carinc
I filled the icemaker manually and it worked. How do I test to see if the fill lines are frozen? Thanks!
#2 Posted : Friday, January 2, 2009 5:00:43 PM(UTC)
Remove the ice maker and visually inspect the water feeding tube. If you could not see, try to put in a stick. Post the results.
The model number you posted is incomplete. There suppose to be a few more letters and digits.
carinc
#3 Posted : Sunday, January 4, 2009 6:30:24 AM(UTC)
carinc
Thanks, I'll let you know how it goes Complete model # is ET18PKXFW01
