gregl
#1 Posted : Wednesday, December 31, 2008 11:39:05 AM(UTC)
gregl
Does the motor relay (part #AP178791) control the power that runs the drain pump on a Maytag DWMDBD820AWW and would be the likely problem after a power surge/black out?
#2 Posted : Thursday, January 1, 2009 2:56:44 AM(UTC)
Here is your parts breakdown includes a wiring diagram
Model MDBD820AWW
Here is a tech bulletin which may apply
http://www.servicematters.com/m...ary/docs/TDD-0011B-B.pdf
First thing to check: is the motor running during a drain cycle?
If yes the check the drain lines for a plug.
The no drain after a power surge may just be a coincidence.
If the motor does not run check windings on the motor with a meter or check that the drain winding is receiving power during a drain cycle.
