efallenbeck@yahoo.com
#1 Posted : Tuesday, March 15, 2011 1:54:08 PM(UTC)
Heat quit less than a week ago...Have replaced both the element and the element thermostat...still no heat...dryer runs, but there is no voltage at the terminals to the element...how is that voltage supplied?..any advice would be great...can't afford a new machine
#2 Posted : Tuesday, March 15, 2011 4:22:21 PM(UTC)
Which part did you call "the element thermostat"? Can you refer to the diagram?
Did you check for 240 VAC at the dryer terminal block? The correct reading should be 120 VAC between the Red & White and the Black & White wires, and 240 VAC between the Red & Black wires.
How did you check the voltage at the heating element?
You also may want to check the power relay (#40 on the diagram).
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KEYS777EQ0 | AppliancePartsPros.com
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Speed Queen (Classic American Top Load) washer (Washer Repair)
by dbdata 10/31/2022 5:20:39 PM(UTC)
littlerich (Oven Repair (including Ranges and Cooktops))
by littlerich 12/15/2014 7:39:24 AM(UTC)
American Appliance Service (Washer Repair)
by my43case 12/2/2014 6:23:37 AM(UTC)
GE Americana top door won't close (Oven Repair (including Ranges and Cooktops))
by bclarke 8/26/2014 4:56:57 PM(UTC)
Commerical Washer Problems (Washer Repair)
by sherryash 12/18/2012 3:11:25 PM(UTC)
Replacing Heating Element on Americana Dishwasher (Dishwasher Repair)
by bryanc1 9/26/2012 7:49:40 PM(UTC)
Americana Refrigerator Freezes Everything (Refrigerator & Freezer Repair)
by floyd3609 5/29/2012 5:58:09 AM(UTC)
Americana Burner Problem (Oven Repair (including Ranges and Cooktops))
by Ken King 2/9/2012 9:21:08 AM(UTC)
Furnace not blowing heat-American STandard (Heating, Ventilation, and Air Conditioning (HVAC))
by johnny wen 12/12/2011 9:35:29 PM(UTC)
speed queen commerical dryer (Dryer Repair)
by mzharleyhoney 12/9/2011 8:49:43 AM(UTC)
is this a water-inlet injector? can I use a generic replacement? (Dishwasher Repair)
by fgnievinski 6/8/2010 9:45:23 PM(UTC)
Americana 8.8 cf refrigerator (Refrigerator & Freezer Repair)
by cmk23411@yahoo.com 3/11/2010 9:30:16 AM(UTC)
Americana 8.8 c/f, refrigerator (by GE?) (Refrigerator & Freezer Repair)
by cmk23411@yahoo.com 3/2/2010 9:39:57 AM(UTC)
1969 GE Americana Stove Oven Combo (Oven Repair (including Ranges and Cooktops))
by bobbyr27 2/15/2010 8:17:44 AM(UTC)
