webratt69
#1 Posted : Monday, December 29, 2008 5:47:34 PM(UTC)
webratt69
My oven worked one day then went to fire up next day and nothing no noises no gas smells just dead, stovetop and display is fine. I know there is both an igniter and a spark control. How can I test these? Just trying to eliminate replaceing un-needed parts.
#2 Posted : Tuesday, December 30, 2008 2:24:50 AM(UTC)
Pull out the oven bottom tray and remove the burner steel plate. Turn the oven on and check the igniter. If it glows, but gas valve doen't open you probably have a bad igniter P# AP3119495.
webratt69
#3 Posted : Tuesday, December 30, 2008 4:00:57 PM(UTC)
webratt69
No glow and no gas flow any other ideas?
#4 Posted : Wednesday, December 31, 2008 12:58:09 AM(UTC)
Check for voltage to the igniter.
webratt69
#5 Posted : Wednesday, December 31, 2008 10:26:17 AM(UTC)
webratt69
Yes have 80 Vac to the ignighter then goes to 126 Vac when I turn it on.Bad igniter?
#6 Posted : Wednesday, December 31, 2008 3:22:25 PM(UTC)
Most flat igniters must draw more than 3 amps to turn the gas valve on, yours is probably bad.
webratt69
#7 Posted : Wednesday, December 31, 2008 3:31:02 PM(UTC)
webratt69
Ok Thank You
