gary2kb
#1 Posted : Sunday, March 13, 2011 6:19:51 AM(UTC)
gary2kb
All of the help areas for replacing the drive belt say to remove the back panel on the washers. Ours does not have a back panel but a wrap around. How do I get the cover off?
sidfink43
#2 Posted : Monday, March 14, 2011 4:21:14 PM(UTC)
sidfink43
Nope, it doesn't. But it is pretty easy to get the front off which will give you access to the innards. Insert a screw driver or flat putty knife in the gap between the top and the front near the edges and you will release clips that hold the front on. Once it is off, you're in business.
Drive Belt Replacement (Washer Repair)
by mzulkoski 6/27/2012 12:49:20 PM(UTC)
Drive Belt Replacement (Dishwasher Repair)
by TerryNi 3/7/2012 1:18:48 PM(UTC)
drive belt replacement (Washer Repair)
by RodE 1/22/2012 1:16:04 PM(UTC)
Maytag Atlantis Drive Belt Replacement ??? (Washer Repair)
by oaktree 9/1/2011 1:44:35 PM(UTC)
Drive belt replacement (Washer Repair)
by Ron C 12/3/2010 4:13:02 AM(UTC)
Whirlpool le58ooxkwo drive belt replacement (Dryer Repair)
by oldguy 8/23/2010 2:04:21 PM(UTC)
by JDS1044 4/24/2010 2:54:16 PM(UTC)
by shadyinc76 12/7/2008 3:00:57 PM(UTC)
by Mikeolaw 8/8/2008 3:51:00 PM(UTC)
