What is easiest and quickiest way to change the drive belt, without taking the whole tub apart? Need help. Ron C
This may help. Start with the section on removing the motor bracket.
Originally Posted by: magician59 This may help. Start with the section on removing the motor bracket. Thanks very much! I knew there had to be an easier way than the one b I was trying to do. Ron C.
