I had noise around the motor and discovered the chopper unit was worn out. In the process of finding this I unnecessarily had removed the motor. I noted that the yoke that engages the chopper unit was a bit worn, but installed the new chopper and tried it. I still had the same noise which is coming from the chopper. I can only assume the yoke is too worn, but looking for that part it appears I need to replace the entire motor. Say it ain't so! The motor runs fine. Sorry I could not give you a better model nuumber but my now ex-wife must have removed the sticker at some point. Thanks. John
John, If the motor itself is still good then you can fix it by replacing just the impeller kit. - The impeller kit Part number: AP3738238
Thanks, Gene. Ordered the part. Looks like just a simple pry off and press fit, no? Thanks again
You are welcome John. The instructions are attached to the reply. Keep us posted. Gene.
