PAJohn
#1 Posted : Friday, March 11, 2011 1:15:36 PM(UTC)
PAJohn
I had noise around the motor and discovered the chopper unit was worn out. In the process of finding this I unnecessarily had removed the motor. I noted that the yoke that engages the chopper unit was a bit worn, but installed the new chopper and tried it. I still had the same noise which is coming from the chopper. I can only assume the yoke is too worn, but looking for that part it appears I need to replace the entire motor. Say it ain't so! The motor runs fine.
Sorry I could not give you a better model nuumber but my now ex-wife must have removed the sticker at some point.
Thanks.
John
#2 Posted : Friday, March 11, 2011 3:26:53 PM(UTC)
John,
If the motor itself is still good then you can fix it by replacing just the impeller kit.
- The impeller kit Part number: AP3738238
PAJohn
#3 Posted : Friday, March 11, 2011 5:46:36 PM(UTC)
PAJohn
Thanks, Gene. Ordered the part. Looks like just a simple pry off and press fit, no? Thanks again
#4 Posted : Saturday, March 12, 2011 2:25:10 PM(UTC)
You are welcome John. The instructions are attached to the reply.
Keep us posted.
File Attachment(s):
How to replace pump & motor.pdf (1,122kb) downloaded 11 time(s).
