Replacement parts for WHIRLPOOL KUDP01FLBT0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.comSee the attachment for the tech sheet.
No heat can be a number of things.
You could try running the diagnostics.
If it passes the thermistor test and the heater does come on when it should then the board is shot.
The easiest to check is the high limit thermostat Item 30 in Section 7. It should be 30 ohms.
Next would be the heating element, it should be approximately 20 ohms.
If the unit uses two door switches it could be the switch is not closing or is shot. It should be 0 ohms when closed.
I would also check the thermistor resistance.
May even be a bad wire or connection.
If all the above are OK then the control board is probably shot.
