paul sparky
#1 Posted : Friday, March 11, 2011 9:16:46 AM(UTC)
paul sparky
dishwasher runs forever about 3hours or more? does not seem to dry the dishes at all. Always standing water on top of dishes. Dishwasher is about 8years old. thank you paul
#2 Posted : Saturday, March 12, 2011 2:54:45 AM(UTC)
Replacement parts for WHIRLPOOL KUDP01FLBT0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
No heat can be a number of things.
You could try running the diagnostics.
If it passes the thermistor test and the heater does come on when it should then the board is shot.
The easiest to check is the high limit thermostat Item 30 in Section 7. It should be 30 ohms.
Next would be the heating element, it should be approximately 20 ohms.
If the unit uses two door switches it could be the switch is not closing or is shot. It should be 0 ohms when closed.
I would also check the thermistor resistance.
May even be a bad wire or connection.
If all the above are OK then the control board is probably shot.
File Attachment(s):
KUDP01F.pdf (1,122kb) downloaded 1 time(s).
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
