kingdaugie
#1 Posted : Thursday, March 10, 2011 10:29:22 AM(UTC)
kingdaugie
I hope someone can help tell me what part I need to purchase. A couple weeks ago I noticed that my Admiral dryer no longer heats at all. It will spin/tumble just fine, but no heat. I also notice that the light in the dryer no longer works when I open the door. Are these issues related? I don't care so much about the light, but I would like the dryer to heat up again. What part should I buy?
Thanks!!
#2 Posted : Friday, March 11, 2011 1:05:04 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for ADMIRAL ADE7005AYW DRYER- ELE | AppliancePartsPros.com
Sounds like you have a power problem, I would say that L2 is out.
The timer and the motor get power from L1 but the heater and the light require L2.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
kingdaugie
#3 Posted : Friday, March 11, 2011 4:57:20 AM(UTC)
kingdaugie
You were absolutely right. 1/2 of my breaker was tripped but it didn't trip both of them. I flipped the breaker off and then back on and the heat and light started working again!
You the man!!!
