They did a poor job sucking out all the non-compresables, not good for the compressor. Best to call them back soon, or you will loose the compressor. The core of the evaporator should chill down to near -20 degrees, if not, that is your evidence.
Originally Posted by: richappy As long as it will not rattle all the time, the compressor should be ok. I sure appreciate this entire thread, just wanted to say THANK YOU :) It's so wonderful to be able to actually fix these things myself, and it's really nice of you all to give advice like this that helps all of us so much and saves us money. Thank you again!
