No water at all coming up...cycles all work etc....no water ?
Hello, Lift the float switch up in the front corner if you hear a click when you are letting it down then its on track and working fine. I would suspect that you either have a bad water valve or the incoming water is shut off or has low pressure. We can test the water valve if you like post back and let me know. ApplianceRepairLesson.com
