Does the red wire or white wire go to the starter relay with the other going to the overload? Does it matter?
Originally Posted by: tomtom4552  Does the red wire or white wire go to the starter relay with the other going to the overload? Does it matter? Tom, Yes it does matter, The RED wire should go to the overload terminal, and the White wire to the relay connection terminal. Good Luck, :) :) :)
