ray1216
#1 Posted : Thursday, July 2, 2009 12:13:33 PM(UTC)
ray1216
My brother has a Trane XE 900 Model# TWD724A100A0 condensor, and the condensor fan motor went out. The old motor had three leads one brown to capacitor, one purple to capacitor and one black to line voltage. the new motor has two orange leads one for the capacitor and one for line voltage, one brown for capacitor and one black for line voltage stated on the data label on motor, We are having trouble getting this wired in correctly. We had it wired with 1-orange to cap. 1-brown to cap. 1-black to line voltage, but don't know where to connect the other orange lead. This made the motor work but it runs continuously.
ioane/tech
#2 Posted : Tuesday, July 28, 2009 4:00:44 PM(UTC)
ioane/tech
do you have the diagram with you ?should be on the side of the motor, check your old motor see if its 120vac
or 240vac...also check your new motor if its the same as your old,,let me know...I can help you withthat
