Originally Posted by: Andromb  Additionally, One of the tabs on the motor end of the ejector is snapped off, so the cam can go on one way, or 180 degrees the other way. My trial/error approach to synchronization resulted with water overflowing everywhere. Please guide me. Thanks That should not have happened, Unless, The ejector arm was jammed or stuck, You accidentally dislodged or turned the water level adjustment screw. You have a bad water fill contact inside the control module. The ideal situation is at the fill cycle the valve should be active for 7 to 8 seconds, and the water amount should be 130 to 140 cc's (1/2 to 3/4 cup)of water in the mold. Even if you had the ejector out of alignment, it still should have filled properly, the ejector would have been in the 6 o'clock position instesd of the 12:30 to 1:00 o'clock. :cool: :cool: :cool:
